Select a temperature factor and define its properties.
The temperature factor icon is enabled when performing SN (uniaxial, multiaxial) and
EN (uniaxial, multiaxial) fatigue analysis.
Click the Material tool.
The Assign Material dialog opens.
Under the Temperature Factor field heading, click
In the dialog, select temperature factor from the drop-down menu.
- None: Ctemp = 1
- User Defined: Enter a Ctemp value
between 0.0 and 1.0
- FKM: Input a temperature in degrees Celsius and
select a material type. Ctemp is automatically
calculated.
Click OK.
The temperature factor is used to update the fatigue strength reduction
factor.
Kf (mod) = Kf /
Ctemp
For more information, see
Temperature Influence.
Tip: Apply a temperature factor value to all the parts/sets by
right-clicking on
and
selecting
Apply current value to all Parts/Sets.
