Select Weld Lines Graphically In addition to picking from a list, weld lines can also be selected graphically using the weld line browser. Click in the weld line browser. Note: This feature is only available in the Mark Welds and Points tools. Use the entity selector to pick weld line components from the modeling window. Click . The selected weld lines are highlighted in the browser.If Components other than welds are selected, they will automatically be excluded.
