HyperLaminate Menus
The HyperLaminate menu bar provides access to menus that allow you to manage files, edit materials, laminates, HLS loadcases and design variables, change views, and access online help.
Tools Menu
- Laminate Options
- Displays the Laminate Options dialog, which can be used to select defaults for new Laminates for:
- HLS Options
- Displays the HLS Options dialog, which allows you to retain the input and result files for the HyperLaminate Solver. You can also choose the location these files are written to.
