Analyze Data Sources
Build arrays of information based on data sources using the row and column index.
  1. From the Post-Processing step, click the Data Sources tab.
  2. From the Channel selector, select a data source.
  3. Select the Table View.
  4. Build a table using the Index column, Row Index checkbox, and the Column Index checkbox.
    1. Enable the Row Index and Column Index checkboxes to display the content of the desired label in the rows or columns respectively.
      Tip: To analyze the data for a specific run or array number, enable the Row Index or Column Index checkbox and enter the desired run or array number in the Index column.
  5. Analyze the table.
