HV-3025: Post Process ALE Results
Learn how to post process ALE results.
- View results on special elements such as ALE using a combination of HyperView tools and settings such as:
- Results Contour
- Iso Values
- Section Cut
- Grid Line
- Transparency
- Feature Lines
- Click the Iso panel button
on the Result toolbar.
OR
- Select from the menu bar.
The Iso panel is generally used to display single iso values (iso surfaces for solids or iso line for shells) dependent on the results data.
