ardi::item::image
Interact with items of type image.
Supported property names are: -name -value -parent -type (read only) -config -hwpage -hwwindow. All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::image create args
- Parameters
- For a full list of property names, see above.
- Returns
- The ID of the item or tcl-error in case an error occurred during creation. For example, ardi::item::image create -name -value "C:/Report Images/myimage.png"
ardi::item::image delete args
- Parameters
- -id (mandatory)
- value: item ID. The item ID which is returned by the corresponding "create" API.
- Returns
- 1 for ok
ardi::item::image get args
- Parameters
- -id (mandatory)
- Returns
ardi::item::image getpropertyid args
- Parameters
- -id
- value: item ID
- -key
- value: property key
ardi::item::image getpropertykeylist args
- Parameters
- -id
- value: item ID
- Returns
- list of property keys for a particular item ID
ardi::item::image set args
- Parameters
- -id (mandatory)
- Returns
- 1 for ok
