ardi::item::textdocument
Interact with items of type textdocument.
Supported property names are: -name -file -parent. All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::textdocument create args
Creates an item of type "textdocument".
For a full list of property names, see above.
Returns
The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::api::item::textdocument create -name "My Text File" -file "example.txt"
ardi::item::textdocument delete args
Deletes the item with the specified ID.
-id (mandatory)
value: item ID. The item ID which is returned by the corresponding "create" API.
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::textdocument delete -id $id
ardi::item::textdocument get args
Queries the value of one property.
-id (mandatory)
default value: ""
Returns
The value of the specified property or tcl-error in case of error usage: ardi::item::textdocument get -id $id -property parent
ardi::item::textdocument getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item::textdocument getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item ID
ardi::item::textdocument set args
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id (mandatory)
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::textdocument set -id $id -name "My Exernal Excel Document" -file "c:/temp/textdocument.txt"
