The external programs called from within the program must be written in C and
incorporate the Altair IPC functions.
Two example programs containing Altair IPC functions are
provided:
Multiplication C-only Filter Example
Simple Example
One example contains C-only source code. The other example contains C source code
that calls a FORTRAN subroutine. The source code for each sample is located in the
install directory for the program.
Note: Altair IPC uses
stdin and stdout to communicate with
the host program. Do not use stdin or
stdout when writing external programs called through
Altair IPC.
