::AddButtonToActionFrame
This command adds a button to the specified frame. Normally it is used to add “Back” and “Next” buttons to the buttons frame of the wizard dialog, but can be used to add any button which can perform any task to any frame.
::model::mdlWizardDlg::AddButtonToActionFrame frame button position text callback
MotionView Tcl GUI
frame
The full path to the action frame of the wizard dialog. This path is usually returned by the ::model::mdlWizardDlg::GetButtonFrame procedure.
button
The name that will be used for the button widget being added.
position
This position is the “column” that the button is to be added in the specified frame.
text
The text that is to be displayed in this button in the specified frame.
callback
The procedure that is to be executed when this button is pressed.
To add the “Back” and “Next” buttons to the wizard dialog:
namespace eval ::my_wizard {
    variable p_dlg ""
    variable panel_list {}
    variable current_panel 0
proc ::my_wizard::Run {} {
    set mangle [::model::GetMangle my_wizard_Run]
    variable p_dlg
    set p_dlg [::model::mdlWizardDlg wiz$mangle -width 600 -height 400 \
        -title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
    set frm [::model::mdlWizardDlg::GetButtonFrame $p_dlg]
    ::model::mdlWizardDlg::AddButtonToActionFrame $frm btnBack 4 "< Back" ::my_wizard::OnBack
    ::model::mdlWizardDlg::AddButtonToActionFrame $frm btnNext 6 "Next >" ::my_wizard::OnNext
    ::model::mdlWizardDlg::SetCloseButtonText "Finish"
    variable panel_list [InitializePanelList]
    DisplayPanel
    ::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::InitializePanelList {} {
    hwi GetSessionHandle sess1
    sess1 GetProjectHandle pro1
    sess1 ReleaseHandle
    pro1 GetPageHandle pa1 [pro1 GetActivePage]
    pro1 ReleaseHandle
    pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
    pa1 ReleaseHandle
    win1 GetClientHandle mcl
    win1 ReleaseHandle
    mcl GetRootObjectHandle mo
    mcl ReleaseHandle
    mo InterpretEntity en1 Point p_abtaf_1 "\"Point 1\""
    mo InterpretEntity en2 Point p_abtaf_2 "\"Point 2\""
    mo InterpretEntity en3 Point p_abtaf_3 "\"Point 3\""
    mo ReleaseHandle
    return { en1 en2 en3 }
proc ::my_wizard::DisplayPanel {} {
    set mangle [::model::GetMangle my_wizard_DisplayPanel]
    variable panel_list
    set tmp [lindex $panel_list $current_panel]
    $tmp GetObjectHandle pCurPoint$mangle
    set lbl "My Wizard - [pCurPoint$mangle GetLabel]"
    pCurPoint$mangle ReleaseHandle
    ::model::mdlWizardDlg::ChangeTitle "$lbl"
    set frmParent [::model::mdlWizardDlg::GetDialogFrame]
    grid rowconfigure $frmParent 0 -weight 1
    grid columnconfigure $frmParent 0 -weight 1
    catch { destroy $frmParent.frmPanel }
    set frm [frame $frmParent.frmPanel]
    grid rowconfigure $frm 0 -weight 1
    grid columnconfigure $frm 0 -weight 1
    set txt "Point: $lbl"
    set wLbl [label $frm.lbl -text $txt]
    grid $wLbl -row 0 -column 0
    grid $frm -row 0 -column 0 -sticky nesw
    UpdateBackNextButtonStates
proc ::my_wizard::UpdateBackNextButtonStates {} {
    variable p_dlg
    variable panel_list
    set nLastIndex [ expr { [llength $panel_list] - 1 } ]
    set bEnableBack [ expr { $current_panel > 0 && $nLastIndex > 0} ]
    set bEnableNext [ expr { $current_panel < $nLastIndex } ]
    if { $bEnableBack } { ::hwt::EnableCanvasButton $frm.btnBack } else { ::hwt::DisableCanvasButton $frm.btnBack }
    if { $bEnableNext } { ::hwt::EnableCanvasButton $frm.btnNext } else { ::hwt::DisableCanvasButton $frm.btnNext }
proc ::my_wizard::OnNext { args } {
    incr current_panel 1
    DisplayPanel
proc ::my_wizard::OnBack { args } {
    incr current_panel -1
    DisplayPanel
proc ::my_wizard::OnClose { args } {
    variable p_dlg
    hwt::UnpostWindow $p_dlg
    return 1
::my_wizard::Run
None.
