amfIMarker GetInitialFrameIndex
Gets the index of the initial frame for which the marker is being tracked.
marker_handle GetInitialFrameIndex
Returns the frame number at which the marker will begin to be tracked during the tracking calculation. The default value of the initial frame index is 0.
Examples
3 = HW_InvalidHandle
Note: A return value of -1 is not an error code in this case, as -1 is the default value for the final frame (see above).
