amfIMarker SetFinalFrameIndex
Sets the index of the final frame for which the marker will be tracked.
marker_handle SetFinalFrameIndex idx
Sets the frame number at which the marker will stop being tracked during the tracking calculation.
idx
The default value for the final frame index is -1, which means tracking will continue until the end of the video.
marker_handle SetFinalFrameIndex 99
Error
An error will be returned if any of the following cases are true:
  • idx is less than -1.
  • idx is greater than or equal to the frame count of the video
  • idx is less than the value returned by amfIMarker::GetInitialFrameIndex
