amfIMarker SetInitialFrameIndex
Sets the index of the initial frame for which the marker will be tracked.
marker_handle SetInitialFrameIndex idx
Sets the frame number at which the marker will begin to be tracked during the tracking calculation.
idx
The default value of the initial frame index is 0.
marker_handle SetInitialFrameIndex 23
Error
An error will be returned if any of the following cases are true:
  • idx is less than 0.
  • idx is greater than or equal to the frame count of the video
  • idx is greater than the value returned by amfIMarker::GetFinalFrameIndex
Standard hwResult error codes:
  • 1 = HW_Error
  • 3 = HW_InvalidHandle
  • 4 = HW_InvalidArgs
