amfIMovie SetSpeedupTracking
Sets the value by which the video resolution will be divided in order to speed up tracking.
movie_handle SetSpeedupTracking divisor
Sets the value by which the video resolution will be divided before calculating the tracking data, in order to speed up marker tracking.
divisor
The default value is 1, which will result in no speedup. A value of 2 will yield the greatest speedup benefit with the safest results. A value which is too high will result in inaccurate tracking results, and higher values yield only marginally better speed. This value will be used by the amfIMovie::CalculateTrackingData API, unless otherwise specified.
movie_handle SetSpeedupTracking 2
Error
Standard hwResult error codes:
  • 1 = HW_Error
  • 3 = HW_InvalidHandle
  • 4 = HW_InvalidArgs
