hgtrans config ClearChannels
Marks all channels to be skipped during translation.
HyperGraphTrans Tcl Set
This command marks all channels in the source file to be skipped during translation. Also clears any data that may have been already read and cached from the source file.
Set hgtrans to read everything from a MADYMO file called “ANGACC” and save it to “ANGACC.abf”, then clear all channels.
hgtrans control SetFile “ANGACC”
hgtrans control SetOutputFile “ANGACC.abf”
hgtrans config SetAllChannelsSelected
None.
Keywords
set channel selection
