hgtrans control GetLabelAliasReplacement
Gets the replacement string associated with a previously defined alias.
hgtrans control GetLabelAliasReplacement subcase, datatype, level, index
HyperGraphTrans Tcl Get
This command gets the replacement rule associated with a previously defined aliasing rule.
- subcase
- The name of the subcase in which to apply the rule.
- datatype
- The name of the datatype in which to apply the rule. (Does not apply if the level is “subcase”.)
- level
- The level of labels at which to apply the rule.
- datatype
- request
- component
- index
- The index of the rule. One-based. It must be an integer greater than zero.
hgtrans control AddLabelAliasRule “head” “cabeza” “Subcase 1” “Displacement” request
hgtrans control GetLabelAliasReplacement “Subcase 1” “Displacement” request 1
Returns an empty string if no matching rule exists.
Keywords
get channel alias
