hgtrans control GetReader
Gets the current scale factor for all time channels.
HyperGraphTrans Tcl Query
This command gets the name of the reader associated with the current input file.
Set hgtrans to read from a MADYMO file called “ANGACC” and then read back the associated reader.
hgtrans control SetFile “ANGACC”
If no input file is selected or no valid reader exists for that file, an empty string is returned.
Keywords
get reader
