hgtrans control SetIncrement
Sets the increment between data points translated.
hgtrans control SetIncrement value
HyperGraphTrans Tcl Modify
This command sets the increment between data points read from each channel in the input file. It is primarily used to pair down large data sets.
value
Value must be an integer greater or equal to one. The default values is one (all data points are translated).
Cause hgtrans to read everything from a MADYMO file called “ANGACC” and save it to “ANGACC.abf”, skipping every other time step.
hgtrans control SetFile “ANGACC”
hgtrans control SetIncrement 2
hgtrans control SetOutputFile “ANGACC.abf”
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslation
None.
Keywords
set increment
