hwIAMFExportOptions GetEncoder
Gets the type of encoding used when exporting AMF video files.
hwIAMFExportOptions_handle GetEncoder
HyperView Tcl Query
This command retrieves the type of encoding used when exporting AMF video files:
"jpeg"
AMF video frames are compressed as JPEGs. This encoding uses the quality setting returned by the hwIAMFExportOptions GetQuality function. This type of encoding can produce a smaller video file than ZLIB encoding, but it is not lossless.
"zlib"
AMF video frames are compressed by ZLIB. This type of encoding is lossless, but tends to produce a larger video file than JPEG encoding.
Note: This parameter is used when exporting AMF files from any client during video capture.
To determine the current encoder used when exporting AMF files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions GetEncoder
Error
Returns the type of encoder used when exporting AMF files, otherwise 0 if an error occurs.
