hwIAnimator Next
Advances the animator to the next frame. If the animator is at the last frame, Next wraps to the first frame.
hwIAnimator_handle Next
HyperView Tcl Modify
This command advances the animator to the next frame. If the animator is at the last frame, Next wraps to the first frame.
Error
Returns 0 if successful, otherwise an error code.
