hwIAnimator Previous
Advances the animator to the previous frame. If the animator is at the first frame, Previous wraps to the last frame.
hwIAnimator_handle Previous
HyperView Tcl Modify
This command advances the animator to the previous frame. If the animator is at the first frame, Previous wraps to the last frame.
Error
Returns 0 if successful, otherwise an error code.
