hwIAVIExportOptions SetSize
Sets the relative image size (in percent) used when exporting AVI files.
hwIAVIExportOptions_handle SetSize size
HyperWorks Tcl Modify
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
size
The relative image size (in percent) to be used when exporting AVI files. Values include 100, 50, or 33.
To set the current relative image size used when exporting AVI files:
mySessionName GetAVIExportOptionsHandle
myAviOptions
myAviOptions SetSize 50
Error
Success (0) or an error code (see below).
HW_InvalidHandle
The handle used to invoke the method is no longer valid.
HW_InvalidArgs
The value of the argument size is not one of those listed above.
