hwIH3DExportOptions GetCompressOutput
Queries whether to apply compression to results during output.
hwIH3DExportOptions_handle GetCompressOutput
HyperWorks Tcl Query
Returns true or false, depending on whether writing results is enabled.
Compression is comprised of two processes: lossy and non-lossy. To produce lossless compression, turn compression on and set the allowable error to zero.
To check if compression is enabled:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetCompressOutput
None.
