hwIH3DExportOptions GetWriteResults
Gets whether the contour, vector, or tensor data should be written.
hwIH3DExportOptions_handle GetWriteResults
HyperWorks Tcl Query
Returns true or false, depending on whether writing results is enabled.
By default, any contour, tensor, or vector data displayed in HyperView is written out. Disabling this behavior results in a smaller file.
To check if results are written:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteResults
None.
