hwIH3DExportOptions GetWriteSolidsAsFaces
Queries whether solids should be written as sets of polygonal faces.
hwIH3DExportOptions_handle GetWriteSolidsAsFaces
HyperWorks Tcl Query
Returns true or false, depending on whether faces are written.
If enabled this option write out wetted faces as shells, saving space over writing the complete set of solid elements. However, only nodal contour data can be displayed on the resulting faces.
To check if solids are written as faces:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteSolidsAsFaces
Error
None.
