hwIH3DExportOptions SetWriteAnimation
Sets whether animation data is exported with the model.
hwIH3DExportOptions_handle SetWriteAnimation flag
HyperWorks Tcl Modify
If animation data is not written out with the file, the output can only be used as a model file. However, the file will be much smaller in most cases without the additional data.
This command is related to the H3D option on the Publish Session dialog.
- flag
- True or false.
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetWriteAnimation false
None.
