hwIH3DExportOptions SetWriteSolidsAsFaces
Dictates whether solids will be written as 3D elements or 2D faces.
hwIH3DExportOptions_handle SetWriteSolidsAsFaces flag
HyperWorks Tcl Modify
If enabled, this option writes out wetted faces as shells, saving space over writing the complete set of solid elements. However, only nodal contour data can be displayed on the resulting faces. (This option only works in the old engine and is depricated).
- flag
- True or false.
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetWriteSolidsAsFaces true
None.
