hwIPage RemoveWindowSyncGroup
Removes a window synchronization group.
hwIPage_handle RemoveWindowSyncGroup syncGroupName
HyperWorks Tcl Modify
This command removes a window synchronization group.
syncGroupName
The name of the window synchronization group you would like to remove.
The following example will synchronize all windows on the current page. Divide your current page into the desired number of windows and load a model into each window.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle pg [proj GetActivePage]
set numberOfWindows [pg GetNumberOfWindows]
set windowIdList ""
for { set i 1} { $i <= $numberOfWindows } { incr i } {
    lappend windowIdList $i
if { [string length $windowIdList] } {
    set syncGroupName "MyWindowSyncGroup"
    pg AddWindowSyncGroup $syncGroupName $windowIdList
    pgr SetWindowSyncGroupState $syncGroupName true; #activate window synchronization on this group
    puts “Current state  of $syncGroupName : [pg GetWindowSyncGroupState $syncGroupName]”
    pg RemoveWindowSyncGroup $syncGroupName
hwi CloseStack
This command returns a warning code if a synchronization group with the specified name does not exist.
