hwIPage SwapWindows
Swaps the contents of two windows on a page.
hwIPage_handle SwapWindows window1, window2
HyperWorks Tcl Modify
window1
The index of one of the windows to be swapped.
window2
The index of the window to be swapped with window1.
Windows are numbered from left to right, and top to bottom, starting at 1.
To swap the contents of windows 1 and 2 on page 1:
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage SwapWindows 1 2
Error
Success (0) or an error code.
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
4 = HW_InvalidArgs - The value of the arguments window1 or window2 is invalid. These must both be greater than 0 and less than or equal to the number of windows on the page.
