hwISession CaptureActiveWindow
Capture the active window to an image file of a specific dimension.
hwISession_handle CaptureActiveWindow type, filename, dimension_type, width, height
HyperWorks Tcl Query
type
The image file type. Options include: BMP and JPEG.
filename
The filename that you are writing the captured image to.
dimension_type
Specifies the width and height units of the final image, which can be in percent or pixels.
width
The number of width units of the final captured image.
height
The number of height units of the final captured image.
To determine if the current plot is drawn with a uniform aspect ratio (in other words, equal width and height):
mySessionName CaptureActiveWindow JPEG c:/temp/fun.jpg percent 150 150
mySessionName CaptureActiveWindow JPEG c:/temp/fun.jpg pixels 1280 960
Error
Success (0) or an error code.
