hwISession SaveReportTemplate
Save the current session to a report template.
hwISession_handle SaveReportTemplate filename
HyperWorks Tcl Modify
filename
The destination filename for the report template.
To save the current session as a report template to "myfile":
mySessionName SaveReportTemplate myfile
Error
Success (0) or an error code.
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
HW_MissingArg - Filename is an empty string.
