hwIWindow GetHTMLOutputType
Gets the window caption used when exporting to HTML.
hwIWindow_handle GetHTMLOutputType
HyperWorks Tcl Query
- JPEG
- AVI
- h3d
- Bitmap
- HTML
This parameter is used during HTML export. It indicates the type of the object created when the user clicks on this window in the HTML report. Not all options are supported by every client.
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage GetWindowHandle myWindow 1
myWindow GetHTMLOutputType
Error
If an error occurs, an empty string is returned.
