hwIXMLFile GetVarnameList
Finds the variable name list of the nodes or folders below the input node.
hwIXMLFile_handle GetVarnameList ident
HyperWorks Tcl Query
This command finds a list of variable names of the nodes or folders below the input node or folder. You must input the node or folder variable name (Templex statement) and the command outputthe node and folder variable names.
- ident
- The variable name (Templex statement) of the node that you want to find the variable name list for.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML “c:/Documents and Settings/user/My Documents/hwsettings.xml”;
XML GetVarnameList section.section.2.entry.2.name;
Error
Returns success (the value of the node) or an error code.
Keywords
HyperWorks
Tcl
XML
Query
