hwIXMLFile SetFilename
Sets the current XML file.
hwIXMLFile_handle SetFilename filename
HyperWorks Tcl Modify
This command sets the current XML file.
filename
The filepath of the file that you want to set as the XML file.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML “c:/Documents and Settings/user/My Documents/hwsettings.xml”;
XML SetFilename “c:/Documents and Settings/muriellesmith/My Documents/test.xml”;
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
XML
Query
