mdlIDataMember GetEnumList
Gets the list of valid enumeration values for this data member.
mdlIDataMember_handle GetEnumList
MotionView Tcl Query
This command returns a list of all the valid enumeration values, or {} if none exist.
To get the list of valid enumeration values for the joint’s align_meth1 data member:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle joint_handle j_cp
joint_handle GetChildHandle my_handle align_meth1
my_handle GetEnumList
my_handle ReleaseHandle
joint_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
None.
