mdlIDataMember GetRawExpression
Gets the raw expression used to specify the value of the current data member.
mdlIDataMember_handle GetRawExpression
MotionView Tcl Query
This command returns the expression used to specify the value for the data member.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle body_mass_handle b_piston.mass
body_mass_handle GetRawExpression
body_mass_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
None.
