mdlIDataMember SetAsObsolete
Marks a data member as obsolete so that the next evaluation evaluates that data member.
mdlIDataMember_handle SetAsObsolete
MotionView Tcl Modify
This command marks a data member as obsolete so that the next evaluation evaluates that data member.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginFlatListFastGet Point
myModelName GetChildHandleByIdx point_handle 3
point_handle GetChildHandle z_handle z
z_handle SetAsObsolete
myModelName Evaluate
myModelName EndChildFastGet
z_handle ReleaseHandle
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns Success (0) or an error code.
