mdlIModel AddNewAnalysis
Adds a new analysis from an existing or new definition/data file.
mdlIModel_handle AddNewAnalysis new_handle, varname, label, data_file_path, def_file_path, create_new_def_file, def_name def_type
MotionView Tcl Modify
This command adds a new analysis using the 'varname', 'label' arguments from an existing or new data and definition file.
new_handle
The handle of the newly created analysis.
varname
The variable name for the analysis.
label
The label of the analysis.
data_file_path
The full file path to the data file.
def_file_path
The full file path to the definition file.
create_new_def_file
This is boolean variable that can take true or false.
true
The ‘def_file_path’ will be created (or replaced if it already exists).
false
The ‘def_file_path’ should already be present.
def_name
The name of analysis definition.
def _type
The type of the analysis.
To add a new analysis from an existing data file:
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName AddNewAnalysis ana_handle ana_0 "\"Analysis 0\"" "C:/temp/data_file.mdl" "C:/temp/def_file.mdl" true ana_def_name analysis_type;
ana_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
Returns the handle of the newly created analysis if successful. If there is an error, an error code will be returned.
