mdlIModelClient GetObjectPickContextList
Gets the list of objects that can be picked from the Graphic Window.
mdlIModelClient_handle GetObjectPickContextList
MotionView Tcl Query
This command retrieves the list of objects that are set in pick context. The objects are set using the SetObjectPickContextList command. In the case where a model is empty (meaning that no entity has yet been added to the model), nothing will be returned. If nothing has been set using the SetObjectPickContextList command for a non-empty model, then MODEL will be returned.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetRootObjectHandle mo
mo InterpretEntity en Point p_0 "\"Point 0\""
en ReleaseHandle;
mcl GetObjectPickContextList
mcl SetObjectPickContextList p_0
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns the list of objects that can be picked from the Graphic Window. In the case of a new Model without any entities added, nothing will be returned. If there is an error, an error code will be returned.
