mdlIModelClient GetRootObjectHandle
Gets the handle of root node of the current model.
mdlIModelClient_handle GetRootObjectHandle handle_name
MotionView Tcl Query
This command retrieves the handle of the root object. The root object is nothing but the Model.
- handle_name
- The handle name of the root.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetRootObjectHandle mo
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns the handle name of the Model. If there is an error, an error code will be returned.
