mdlIModelClient GetSaveOption
Gets the value for the given key. The key value can be set using the SetSaveOption command.
mdlIModelClient_Handle GetSaveOption key
MotionView Tcl Query
This command retrieves the value for a given key. The key value can be set using the SetSaveOption command.
- key
- The saving option which can be queried. Valid values are: data, include, write_solvermode, or topology.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetSaveOption topology
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns the option value for the given key. If there is an error, an error code will be returned.
