mdlIModelClient IsDirty
Evaluates whether the changes made in the model are saved or not.
mdlIModelClient_Handle IsDirty
MotionView Tcl Modify
This command evaluates whether the changes made in the model are saved or not.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
set temp [mcl IsDirty]
if {$temp == "true" } {
puts "It is Dirty"
} else {
puts "It is Not Dirty"
sess1 ReleaseHandle;
hwi CloseStack;
True is returned if changes have been made to the model, otherwise false is returned.
