mdlIModelClient RunSolverScript
Runs a solver script.
mdlIModelClient_Handle RunSolverScript Filename
MotionView Tcl Modify
This command displays text in the message log.
- Filename
- The name of the xml file to be used as the solver script.
Creates a model using the file specified.
Copy the file slider_crank.mdl into the present working directory.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl CreateModel "slider_crank.mdl" mdl
mcl ExportModel "model.xml"
mcl RunSolverScript "model.xml"
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
None.
