mdlIModelClient SetReportLogFile
Sets the report .log file.
mdlIModelClient_Handle SetReportLogFile Filename
MotionView Tcl Modify
This command sets the report .log file.
- Filename
- The name of the file which is to be used as the report .log file.
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetReportLogFile reports;
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
Returns 0 if successful.
