mdlIModelClient SetTaskWizardFile
Sets the task wizard file for the specified profile.
mdlIModelClient_Handle SetTaskWizardFile filename, arg_Profile
MotionView Tcl Modify
This command sets the task wizard file for the specified profile.
filename
The filename of the task wizard file for the specified profile.
arg_Profile
Valid arguments are:
User
Settings specified for the user profile
Pref
Settings specified in the preference file
Copy the task wizard file into the present working directory, rename it as file_taskwiz, and run the example below:
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetTaskWizardFile file_taskwiz User;
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;
Returns 0 if successful.
