mdlIObject GetFullVarname
Obtains the full variable of the child object.
mdlIObject_handle GetFullVarname or [set varname mdlIObject_handle GetFullVarname]
MotionView Tcl Query
This command obtains the full variable of the child object. You need to grab the appropriate handle to get the desired variable name. The full variable name is used when the variable is used as an argument, etc.
An MDL model must be loaded prior to using this command.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginFlatListFastGet Body
myModelName GetChildHandleByIdx body_handle 2
set Body_Var [body_handle GetFullVarname]
myModelName EndChildFastGet
body_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns the full variable of the child object, which can be stored as a string in a variable or a list.
