mdlIObject GetLinkedSystemList
Gets the list of the systems which are linked to particular system. Linked systems can be either DATA or DEFINITION linked.
mdlIObject_handle GetLinkedSystemList type
MotionView Tcl Query
This command obtains the list of all the systems which are linked based on the type specified. If the type is DATA, then a list of systems which are linked by data will be returned. If the type is DEFINITION, then a list of systems which are linked by definition will be returned.
type
The type can be either DATA or DEFINITION.
To obtain the list of all the systems which are linked based on the type specified:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName AddSystemFromNewInlinedDef new_handle System sys_0 "\"SYSTEM 0\"" def_sys_1
myModelName AddSystemFromDefInMemory sys_handle sys_1 "\"SYSTEM 0\"" def_sys_1
sys_handle GetLinkedSystemList DEFINITION #It will return MODEL.sys_0
sys_handle ReleaseHandle
new_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns the candidate list if successful.
