mdlIObject InterpretSet
Adds a new set statement to the system.
mdlIObject_handle InterpretSet keyword, tokens
MotionView Tcl Modify
This command adds a new set statement to the system. You must specify all tokens for the requested MDL set statement.
keyword
The new entity's MDL statement keyword.
tokens
The remaining tokens for the corresponding MDL statement.
To get a handle to the parent system of the point p_0:
Note: The mdlIObject InterpretSet command is used to set the x, y, and z expression for that point.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity point_handle Point p_0 "\"My Point\" "
point_handle InterpretSet SetPoint p_0 "1+1" "2+2" "3+3"
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns 0 if successful, otherwise an error code.
