mdlIObject IsGraphic
Determines if the entity is a graphic entity.
mdlIObject_handle IsGraphic
MotionView Tcl Query
This command determines if the entity is a graphic entity. Grab the appropriate handle for this command.
To check to see if an entity is a graphic entity:
Note: Load the slider_crank.mdl model file before running this example.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle gra_handle gra_crod
gra_handle IsGraphic
gra_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns true if the entity is a graphic entity, otherwise false.
