plt3DIAxis GetMetaData
Gets a named meta-data value previously associated with the axis.
plt3DIAxis_handle GetMetaData
HyperWorks Tcl Query
Metadata can be any string or string representation of a number. Returns a string (the meta-data value).
To set and get a meta-data value from a 3D axis:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle myAxisName x
myAxisName SetMetaData species dog
myAxisName GetMetaData species
Returns an empty string if the value is not defined.
