plt3DICurve GetMetaData
Gets a named meta-data value previously associated with the curve.
plt3DICurve_handle GetMetaData
HyperWorks Tcl Query
Metadata can be any string or string representation of a number. Returns a string (the meta-data value).
To set and get a meta-data value from an existing curve:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetCurveHandle myCurveName 1
myCurveName SetMetaData species cat
myCurveName GetMetaData species
Returns an empty string if the value is not defined.
